Thread: What pressure for air testing copper?
    DIY Senior Member seaneys's Avatar
    May 2007
    Chicago Suburbs
    Default What pressure for air testing copper?
    Hello,
    I'd like to pressure test my vertical spa installation (lots of fittings). It has held 40 PSI for 4 hours.
    What is the recommended air pressure and set time for air testing copper? The valves are installed. I did not want to risk over pressurizing the valves.
    Steve
    Plumber RioHyde's Avatar
    Cincinnati, Ohio
    100psi for 30 minutes here
    Default test
    The valves are rated for 150 psi working pressure and no common compressor is allowed to exceed about 125 psi, so you couldn't damage the valves.
    May 2007
    Chicago Suburbs
    Thanks a ton! The max pressure was exactly what I was just scratching my head about.
