Results 1 to 13 of 13
Thread: Bladder Replacement ??
    Default Bladder Replacement ??
    I have just replaced my pressure tank because i could not find a replacement bladder for my older tank (5yrs old). It was a 42 gal Flotec , so here is my question . Why sell a tank and claim it has a replaceable bladder if they don't make a replacement bladder. ???. If they do make one can someone direct me in the right directionto look on the net. TIA
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    According to the pros that I've seen address this subject, it is far easier and better to just replace the pressure tank than a bladder, for a number of reasons. Your's is one of them.
    Mike
    Default Yes, But
    I understand that it is much cleaner and less frustration if you buy new tank . However , iam interested in knowing the price difference from replacing the bag to replacing the whole tank.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Fifty bucks, maybe, and you still have a rusty old tank.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Here is a link that shows part numbers for replacement bladders. http://www.flotecpump.com/pdf/FP490.PDF
    The problem is that tanks are often discounted due to competition among suppliers of tanks. Since there is no competition for replacement bladders you are probably going to pay list price. Add to that the fact that you will probably have to pay an additional labor charge for replacing the bladder, I suspect that it would cost more to have a pro replace the bladder than to replace the tank.
    Jan 2008
    Virginia Beach, VA
    Default Replacing the tank was the right choice.
    As a selling point several tank companies used to advertise replaceable bladders.
    Most people and installers found it was best to just replace the tank.
    Previous member
    Jul 2005
    Riverview, Fl.
    You can't imagine what that tank looks like on the inside. Not only is it nasty, but if you have iron, some iron can form little spurs on metal as it builds up. The Flotec bladder is not by any stretch top of the line, so imagine what those little spurs are going to do to the new bladder.
    I changed one bladder. What a mess. I will never do it again.
    bob...
    Rancher
    Guest
    A quick look at the prices, not including shipping.
    New 42 gallon Flotec tank $109.99 (Northern Tool)
    New Bladder for that tank is $79.00 (Pump Agents)
    So how many hours are you going to take to replace that bladder 1-2 hours for saving $30? And then you still have an old tank.
    Rancher
    Previous member
    Jul 2005
    Riverview, Fl.
    And for $30.00 dollars more, you can have a quality Bladder Tank the same size with a 5 year warranty.
    bob...
    Rancher
    Guest
    Is that with free shipping?
    Rancher
    Previous member
    Jul 2005
    Riverview, Fl.
    Sure if he can get the order up to $500.00 or better. Then it's free.
    bob...
    Smile
    OK , Thanks for the info . This is what i was looking for and i see from the responses that it is not worth the hassle to replace the bladder . Thank you
    Central Florida
    I've replaced bladder fuel tanks in aircraft, which are designed to be replaced, and they are no fun. I suspect the tank bladder is at least as bad, although you aren't breathing gasoline fumes...
