Problem installing drain in Maax shower kit.
Sterling
Alberta
I purchased a Maax ABS shower kit and it includes a "Wedge-lock no-caulk" drain assembly. The instructions indicate that the drain pipe needs to be 1/2" below the bottom of the base. The problem is that the bottom of the base at the drain hole measures only 1/4" to the concrete basement floor. I have already chiseled out a 5" diameter, 2" inch deep trench in the concrete around the drain pipe to accomodate the drain assembly. But how can I cut the ABS drain pipe 1/4" below the level of the floor?
All things are possible, some just take more time and money than others.
Normally, when installing a shower drain, I have the concrete knocked out around the drain, a fairly good hole. This allows me to use a small saw, or maybe just a saw blade that I hold in my hand to cut the pipe.
If the pipe is too short, then the big hole allows me to go farther down and couple on more length.
Sterling
Alberta
Thanks for the thought-starter.:)
I wonder if a cutting wheel on a dremel would work?
That might work, but an inside pipe cutter only costs about $10, and works well.
