First off, Wanted to say hello and give some background on me. I am a pretty capable guy and spent my younger years framing, flashing and roofing houses so I am no stranger to any type of construction. For the record do know when to call a trade specific professional. Ok, now for the questions
I live in a small (900 SQ) house built on a slab on foundation wall and footing. I am building an addition (440SQ) this spring. I will handle the majority of the work myself. The largest problem right now is HVAC. Currently I have a newer Intertherm/Nordyne downflow unit with central air. All ductwork is under slab. I have checked with the contractor that installed my unit and they completed a manual J stating that I will be okay with the new added space.
So, what are my best options to duct the new addition?
Should I go through the foundation wall? will require some steel support and really push the space being heated by the two 8" ducts I could tap from
Can I add a duct to the downflow plenum in the utility room and duct through the attic? This sounds easy being there is room around the base of the furnace, is it?
Also woud it help to add a second col air return in the furthest end of the new space to aid the airflow?
I have called a few HVAC contractors in the area and none seem the slightest bit interested in getting involved i this. It is Winter in PA.
I welcome all advice
Andy
Andy
