howarddor
I have a new frost proof faucet and it continues to run a small stream when shut off. I'm sure of the inner works of a frost free. Any ideas why it won't completely shut off. Howard
Frost free wall hydrant use washers same as a compression cartridge, over time the washer molds to the seat and wears out.
You should be able to remove the nut holding the shaft and replace the washer, but it's not easy most of the time.
Most frost free's are threaded into a fitting in the wall you may want to replace the unit if you can, it would be easier.
Some inexpensive frost-free hydrants use an O-ring instead of a compression washer, and I've seen split O-rings in them.
