country_jack
- Messages
- 2
- Reaction score
- 0
- Points
- 0
A problem developed recently. The new jet pump seems to work fine when delivering water to the household fixtures; taps, toilet, shower, washer, etc. But when I run the garden hose the pressure quickly drops to zero. The pump cuts in at about 25 psi and continues to run while the pressure drops. Turn the hose off and pressure comes back up to 40 psi in a minute or two. No evidence of sucking air and I haven't been losing prime. It's a shallow well setup. 55' deep well, water is about 20' from the surface. The pressure tank is about 3 years old and is pressurized to 2 psi below cut in. Could this be a problem with the foot valve not opening fully or possibly the pressure tank? Suggestions appreciated.
