Results 1 to 2 of 2
Thread: Galvanized > Poly fitting question
    Default Galvanized > Poly fitting question
    I'm putting in valve controlled 'hydrant'. I'm using galvanized pipe for the hydrant itself. Then, underground I elbow out, convert to poly via a threaded poly fitting (drain is in a poly tee) , then onto the poly run up the valve.
    Do I need to pipe dope or teflon the galvanized to galvanized joints? My guess is it's obviously yes (preferably pipe dope?). Then, teflon the galvanized to poly? Am I right on my thinking? Any better way to do this whole setup besides a prefab hydrant?
    TIA!
    Bill
    DIY Senior Member Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    teflon tape is fine.
