In a few months I'm planning on installing a new master bath steam shower with a steam generator. I'm trying to think thru some of the pre work prior to the full remodel. In trying to figure out where to put the steam generator I need some clarification on what the drain needs to do for the overflow. I invision the drain for the drain pan similar to a washing machine drain. With a stand pipe, p-trap, drain run on angle with vent. Here are my questions.
1) Overall what is a typical design for a drain pan drain.
2) If the drain pan is never or hardly ever used. How do you keep water in the p-trap?
3) Won't gases come out of the pipe if the drain is never used?
4) What size pipe do I need to use for the drain?
I may have some other questions as I decided where to put the drain pan but right now this has me confused.
Thanks!!
Thanks!!
