We can't tell if this is the cause of your leak. But , the flange really should be supported. It is supposed to sit on top of the FINISH floor, so it may still be a little low, but that can be dealt with.
SInce you have access from below, you could sister in some joists as necessary to support some plywood which could be cut to fit in around the flange for support.
