prashster said:
It's a short run about 10 feet. Soldering was not an option. Could have pex'd it, but cpvc seemed the easiest. Seriously, is cpvc really bad? In the neighboring town, they plumb entire houses with it.
My statements stem straight from being a service plumber that has to deal with numerous types of piping systems. Being in that mix daily allows me to see what is good bad and indifferent.
I'll admit to heavy bias against CPVC because the reasons it is replacing copper in my area is solely price. Price because it's so easy a caveman can do it and price because it's 4 times cheaper than copper.
That product "if disturbed" years down the road is brittle.....that's a fact. Nothing worse than replacing a water heater and I'm dealing with a system of fittings over sections of pipe, try to be careful and the **** breaks at a tee or short piece between fittings. Now I'm expanding the work detail without choice.
Copper is far more forgiving, durable and took skill to install. It's not really worth the debate as too often the people that support it (CPVC), don't have to deal with it when it breaks like I do.
The laundry tub faucet I installed yesterday had copper water lines that were 52 years old, not one sign of deterioration, no buildup on the inside walls of the pipe. I've pulled out CPVC already that had a black film that I have no clue what it was.....but the people weren't sick so that was a good thing.
So in my specific area of northern kentucky, copper is the best product. CPVC is taking over in new construction and the homeowners are concerned as the product looks horrible no matter how many ways you support it. The inspectors told me that 3' is the rule for support and when I mentioned a shorter distance...they said you can't, it grows/contracts too much to do that which would bring on another set of problems.
Go to replace an angle stop on CPVC that is 10+ years old and see how much fun it is when you bust that pipe off back to a tee, between two studs, and you was being careful when you was cutting it. I've been there and the customer is understanding IF you tell them ahead of time the characteristics of the piping and what to expect when dealing with the aged product.
In Pompano beach florida I'm told copper is fine in those homes and no problems whatsoever. The family I know down there worked for Balisteri Realty and never once mentioned copper failures in that area. I do know that certain areas in FLA has water issues......that's all it is. It's the water, not the piping that is to blame. Why don't they make a effort to protect the community from deteriorating piping systems when they can address the problem at the plant? That's all it is and the turn down costs tons to fix. I'm sure it costs bunches to treat the water as well, I'm sure.
