Results 1 to 3 of 3
Thread: Unstable shower pipe
    DIY Junior Member mastermy's Avatar
    Jun 2010
    CA
    Default Unstable shower pipe
    Hi all,
    My husband and I did a shower renovation and replaced the shower cartridge for a moen shower valve. Before we sealed it with the cover plate we tested it out. It is hard to pull the shower handle out and we can see the pipes moving forward as we do. Is there anything we can do to fix it?
    Background info: we did a whole new tile installation with new durock. We made sure the the valve plasticguard is flush with the finished wall(the tile).
    Thanks,
    Myesha
    Depending on the valve, it may have screw holes to anchor it to a piece of wood blocking, or you may have needed to use straps or clamps to hold the pipes which would hold the valve in place. Also, you might want to take the cartridge out and put some plumber's grease on it, it may help move easier. the plaster guard is there just to be a guide on proper placement and help keep crud out while you are putting up the finished wall - it generally isn't used to support the valve (some thin wall installations may be the exception). In most, you can and should remove it once finished. Probably won't hurt anything, but most are not designed to be left in place during use. If there's no blocking in the wall, or the pipes aren't well supported, you won't be able to firm it up without getting in behind - maybe through a closet, so you don't have to tear up the tile.
    You need to secure the valve, but a new Moen cartridge should NOT be tight enough to cause the movement.
  1. Unstable tub floor
    By Serg in forum Shower & bathtub Forum & Blog
    Last Post: 11-01-2013, 06:27 PM
  2. shower pipe to plumbing
    By bhumm in forum Shower & bathtub Forum & Blog
    Last Post: 12-20-2006, 01:07 PM
  3. Shower Pipe Replacement
    By GoDillos in forum Shower & bathtub Forum & Blog
    Last Post: 07-26-2005, 03:45 PM
  4. Shower Pipe Installation
    By MikeG in forum Shower & bathtub Forum & Blog
    Last Post: 04-21-2005, 02:23 PM
  5. Shower pipe question
    By dcgee27 in forum Shower & bathtub Forum & Blog
    Last Post: 02-28-2005, 11:32 PM
