Results 1 to 5 of 5
Thread: Plumbing a shower and tub drain together?
    Default Plumbing a shower and tub drain together?
    I have a tub and want to add a shower. Is it good practice to plumb both ahead of a common drain bucket?
    Default tub and shower
    What do you mean by a "drain bucket"?
    I wonder if he/she means a drum trap?
    I am not sure what the correct term for the plumbing (P-Trap?) that provides the vapor barrier for a tub drain. It is below grade (under the slab) so I can not see it. All that is visible is the tub drain run down thru the concrete. So I want to tee a shower drain in just above the concrete level.
    Default no go. two drains, two P traps. Back to the drawing board.
    And then, here's more:
    -- -- separate connections to the stack or else separate venting.
    lots to learn.
    david
