Molo
Hello All.
I cut this hole in the floor today when I realized the floor was sloping under the toilet, and it was all rotted. The toilet had been leaking, and the floor joist was cut in front of the drain-pipe with no other support built for it!
Questions are:
1. The cast iron flange still appears to be solid, should I leave it or replace it?
2. If it needs replacing, what material should I use, and how should I do it? It is a lead and oakum joint set-up.
http://www.ufpi.com/literature/acqfastener-216.pdf
Questions are:
