Construct30
How do you know this is low-voltage wire????
The OP is in LEBANON!!! The country, NOT Lebanon Pa.
Have you seen the type of wire they use there? I haven't. Maybe that is standard issue wire.
You know originally I did not say it was low voltage wire, someone else did. Once you jumped on me about it, I looked at the blown up picture and agreed. Everyone could take your route on this forum and there would be no forum, I gave no bad advice just information. I could have said it doesn't matter hook it up, but I didn't. That would be bad advice. Instead I gave information based on the little that we know and can see. I can go to any question asked on this forum by a DIYer and say we can't help you go away, many choose to try to give information. I try really hard to not give advice that would put someone in danger, if/when I do I'm glad that there are others here that will catch it and when that happens I will back down and admit I was wrong. In this case urging caution was in my opinion the correct thing to do. IF it is the correct wire and switch then buy a box and some conduit and run it properly. If you want a temporary switch system on a lamp then buy a ready made lamp with a remote set of switches.
