Who runs more plastic than copper nowadays?
Rap
california
I've heard guys say that they mostly use plastic in preference to copper these days - is this the common experience?
Hackney plumbing
Homeowner
Alabama
Plastic DWV for me for 99.9 percent of my installs. My higher end customer want copper(for potable) and I suggest copper if they currently have a copper system however somtimes the job dictates the best type of pipe to use.
Hackney plumbing
Homeowner
Alabama
Alot of people think copper would last forever in a DWV system but installed in the wrong location without protection this is what can happen.
Gary Swart
Yakima, WA
PVC and ABS are practically indestructible. Copper is wonderful for water lines in most places, but there are some areas that have minerals in the water that eat copper so CPVC or Pex are used for supply lines. As you can see by the previous post, copper and acids found in drains don't mix too well. Add the very high price of copper to the mix, I can't imagine why anyone would use copper for a drain system. You can see in the above photo the drain is eaten up, but the supply lines are in like new condition.
Hackney plumbing
Homeowner
Alabama
Sewer gas caused that DWV copper to fall apart.
Rap
california
Thanks for the replies. Hackney, i've occasionally seen degraded DWV Cu. like in the pic. But how can you be sure that it's the, admittedly corrosive, sewer gases? Was the structure on a septic tank, or unusual disposal conditions?
Hackney plumbing
Homeowner
Alabama
I did the repair and there was alot of sewer gas flowing. It was unusually bad.
The home is connected to a city sewer system.
Gary Swart
Yakima, WA
The plumbers in this area who use plastic for water lines are the ones doing the "cheap" jobs.
I think there are places such as at least part of Florida that have problems with copper water supply lines.
Psjr56
S. Jersey
Guy at work had to replace his copper with CPVC because his well water kept making pinholes in the pipe.
