Which Well Pump
dm0978
Altus, OK
I have a submersible well pump feeding a 1500 underground storage tank. I now want to install a pump which will draw from the storage tank and feed an undergound sprinkler system. Should I buy a conventional jet pump with a pressure switch and pressure tank, or an electronically controlled pump, which requires no pressure switch or tank?
Wet_Boots
Sprinkler Guy
Metro NYC
Conventional jet pumps are not too shabby in this application. Their 'sweet spot' is right in the operating window of common lawn sprinkler heads. A baby pressure tank combines with the pressure switch already on the jet pump to give you a complete supply for a sprinkler system.
dm0978
Altus, OK
I've looked at the Pside-kick. I think I understand it, but I'm not sure. How is it different than a pressure tank, pressure switch, and water pressure regulator combination.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Conventional jet pumps are not too shabby in this application...
Jet pumps have a more pronounced curve and as a result the loops are easier to tune to match the curve. A sub would be more energy efficient if properly matched but they may be harder to match due to their curve.
A CSV would allow for a wider range of GPM and save having to tune the loops. When used with a CSV, a sub that does not float each impeller would likely draw less power than one that does.
