So our old toilet was knocked loose surprisingly easily, and we removed it to find this:
The flange is embedded in the concrete. And the bolts were NOT in the proper slots on the left & right; rather, they were in the warped/broken notches on the top and bottom (where the concrete was carved out below the notches). Yet another surprise from the previous owners of this house.
Rather than an expensive job of digging up the concrete and installing a new flange -- something I am not skilled/qualified to do, and can't afford right now to hire someone -- I have read about people successfully using repair rings. So I cut out the warped parts of the flange and used some Quikrete to fill in the holes and level the concrete around the embedded flange. I'm thinking this should be solid enough to use a repair ring, as I won't be drilling into the Quikrete. I picked up some 1-1/4" long Tapcons and found a few different rings. Any thoughts on which would be best?
The first two are Superior Tools Super Rings (original model -- and some new differently shaped one; not sure if there's a benefit), and the second one is a stainless steel Sioux Chief Repair Ring . If anyone has any thoughts on or experience with any of these, your advice is much appreciated. Thanks!
