Construct30
jar546 how do you like to see the seal?
Bad install including that goofball purple primer.
That goofball purple primer is required by some inspectors to make sure idiot plumbers that think it is unnecessary used it.
Then there must be a lot of idiot plumbers in the area to make that change to the code to enforce such a requirement. Maybe a lot of ferncos above ground as well.
We don't have that problem here in Kentucky, we don't have to be babysitted when installing piping systems.
You know I would love to read the book that you wrote, I'm sure you must have one. Anyone that knows everything should have their own book to help us poor unlearned people. How else can we ever learn if intellegent people such as yourself don't share their vast knowledge? OR Are you just a legend in your own mind? Oh when you write that book make sure you add lots of pictures or it will do me no good.
For your readin' pleasure http://www.fernco.com/speccode.asp
Also check this out http://www.fernco.com/NH.asp Fernco is a brand not a single product!!!
Kentucky must be proud to have all the perfect plumbing. Been there seen some horrific sites in construction. Seen some darn nice work too. Sort of like any place you go.
Water lines must be sleeved too per IRC too. P2603.4
As far as purple primer is concerned, guess what? Now required under the 2006 IRC. P3003.9.2
It's just as easy to do it right as it is to do it wrong unless you have to do it all over again because you did it wrong the first time.
FYI I haven't used a fernco for going on six hours now .
