What would raise pH while lowering hardness?
jwober
ohio
I install a new Birm iron filter with AIO3 injection. The pH has gone from 7.6 to 9.0 and the hardness has gone from 8 grains to 1, neither of which should happen with Birm. Any thoughts of what was accidently put in the tank instead of Birm
jwober
ohio
Well, 10 days and 3 more backwashes later the pH and hardness seems to be coming back to normal. I guess it was the Birm finds
It is called BIRM (best iron removal media)....
I don't know how the softness went down. Is the iron down? You may be able to determine that by taste.
jwober
ohio
Thanks for pointing out the typo. Yes, the iron tested at 0 ppm. Since the pH and hardness have returned to normal over te last 3 weeks I can only assume there were some Birm "fines" that got cleaned out??
The fines thing may be a thing... I think you are declaring success.
