MHM
I am considering placing a tempering tank in the attic space above my garage to pre-warm my well water before the tankless hot water heater. It gets quite hot up there. I recognize that I could only use it for about 2/3's of the year but the house is used primarily during that time any way. I would have to drain and bypass the tank during the winter months. I will have a standard pressurized well tank in the system at all times. The tempering tank would be placed after the well tank.
I'm considering something like: http://www.homedepot.com/p/Water-Wo...tical-Retention-Well-Tank-ERTG42T-A/206780899
Water Worker Model # ERTG42T-A Epoxy Coated 42 Gal. Vertical Retention/Well Tank
I would probably go with the 82 gal version if they still make it.
Can I use a lower port for the water inlet and the top port for the water outlet?
Is the lowest port low enough to properly drain the tank in the winter?
Do I need to maintain any air in the tank?
If the water temp gets above my tankless HW heater set temp, will that cause any problems with the tankless system?
Do I have to worry about legionnaires disease with this setup? It could go a week or so at a time without any draw down. I've seen several comments about that online.
I realize the tank will probably sweat but no worse then the well tank before it.
Any other tank recommendation?
Thanks for your time.
