Mihomeowner
Have been having well pump issues for a couple days. Water was intermittent... sometimes would be fine, but other times nothing. So I finally popped the cover off the pressure switch. We had a lightning strike to a very close tree a few months ago. Lost some TV's and network cables. When I took a look at the pressure switch, I could see some "charring" that I also saw inside some of the other electrical devices that got lost. The wire that had the charring was one of them leading to the well pump
So I thought, this shouldn't be too hard, and replaced the pressure switch. But I am still having issues. I've checked the voltage going to the well pump and it's 240v, so that should be fine. I don't have an amp-clamp so I can't check the amps. But the well pump should be energized and right now it's not even able to get up to 40psi. So after a couple hours of troubleshooting, I am guessing my well pump might be dead. Could it have died a few months later due to the lightning strike? It's a 10 year old pump, but the fact that I saw some "charring" on the pressure switch leads me to believe the well pump got hit as well.
Now my question, I am going to get a well guy out here because we don't have water. I have a 1.5hp well pump. Assuming it's dead, is there any advantage to upgrading the pump? The pump was previously on a 30-50 psi but when I changed the pressure switch I went to 40-60psi (and changed the air pressure on the bladder).
This is my current pump:
http://waterpumpspro.com/index.php?main_page=product_info&cPath=109_171_173&products_id=4353
It's a 2-wire. Thanks for help
