Stackz
ok.
so here's the last thread:
https://terrylove.com/forums/index....t-pump-cycling-on-a-shallow-well.94140/page-3
going to list on friday and I "think" I can rig it up to hold pressure but anyway...
I just figured it would cycle the pump because I was still only using a 1 gallon tank. then I sat and watched it after I got all of the sprinklers setup and running (CSV works beautifully btw). anyway. I looked around and then noticed wet at the well head. sure enough, I can hear it "simmering" or leaking air. messed around with it and its actually the head itself as it clamps onto the drop pipe (or whatever you call it). the drop pipe is like this big long black tube. you can actually buy it at lowes still even though my grandpa did this thing way back in the 60s.
The wellhead itself is an upgrade I did myself by taking the cast iron outer pipe and threading it and then upsizing until I could get this 4" head on it.
I'm thinking I can just loosen the head, wrap it in electrical tape (or whatever I need to wrap it in to get a positive seal on it) and then tighten it back together. aside from this point, it hold pressure.
I can literally pull up/down on the pipe elbow and I know I shouldnt be able to do that haha. I mean if I have to replace the seal itself so be it but I ordered this thing online like 8 years ago and have no clue what to replace it with...and I'm on a time crunch.
any ideas?
any ideas?
