PVC glue and cleaner... AIR FLOW.... AIR FLOW..... or you will get Higher than a kite in high winds.....
The neutralizer should have came with a back wash flow control... say 5 gpm, if that is the case then there should be no problem about the media going out the back wash line as long as there is 17" of space between the media and the bottom of the threads at the top of the tank.
Softener unit is much like the AN or neutralizer... head space or clear room between media and bottom of threads at the top of the tank and a flow control of say 3 gpm... and all should be good.
No need to change the piston on the 5600, just have it clean or cycle every 2 or 3 days and that should be great... you have little to no iron that is going to challenge the media .... just low ph and Hardness...
If you no longer need the Rusco spin down,, Sell it to some one that does...
