Chris Fox
Of all things going on right now with the bath remodel I find that I have water running somewhere. Where the water main comes into the house(near the garage) I hear a hissing(the sound of water runnig through the pipes).
1. slab home 1994
2. I checked all my connections even cut into a wall to check lines to shower - no water leaks
3. The water softener shows its in service so the split to the irrigation tells me its in the house.
4. I did find my bleed screw on the irrigation valve was leaking(so one leak solved)
5. i figured I am using 720 gallons month(2 adults and a 2.5 year old) The facsination of flushing toilets from my toddler is about 3 days old now! which isnt helping my water usage.
6. the water bill increased 5 bucks - assuming the irrigation bleed screw is the culprit for this.
So the dreaded slab leak is looming over me. Any ideas on where the water could be going before I call a plumber?
Chris
1. slab home 1994
Chris
