Water Pipes Howling/Whining
Kickassness
Louisiana
The other night my girlfriend and I were sleeping in bed when at around 5am we heard some whining. We thought it was our dog, but when we checked, he was asleep. The noise continued and after some investigation, we concluded it was our water pipes. We could not, and still cannot, find the problem. There has not been a lack of pressure, everything works fine, and the only lead I had was our bedroom toilet which takes maybe 3 flushes before it is done to refill. I shut the valve off to the toilet, but the pipes still howl. So I assume it is not the toilet.
There does not seem to be a theme to this noise. It happens randomly, mostly when no water has been running.
FYI, we have a well system with a filter and an electric water heater. I checked the pressure of the system and the gauge is reading 45-55 psi.
Any ideas?
Do you have a water softener or backwashing filter? If so, that may be the cause... My softener with an old Autotrol controller does that.
Kickassness
Louisiana
The well does have a filter system that does flush excess water outside. That is the only thing I can think of though. I'm not great with plumbing
CountryBumkin
Active Member
Orlando, FL
Dogs whine in their sleep too. And they growl, kick, snore, and move around while sleeping.... :D
I haven't had a good night sleep since I let my puppy (now 100lbs) sleep on the bed with us five years ago.
Post the make and model info of the controller (on top of the tank) and/or post a photo of the controller with any lift-off cover removed.
Kickassness
Louisiana
I will have to do that later. I am at work right now. But I will post it as soon as I can
