KD
- Messages
- 207
- Reaction score
- 0
- Points
- 0
Water bill is $250 per month, used to be $100. Can not find any leaks, both toilets have no leaks. With no one using water in the house, the little flow triangle on my water meter is stationary for about 5 seconds, then it moves forward, then backwards, then it bounces to a stop. 5 sec. later it does it again. sometimes it rotates in reverse first.
1. If I shut off the main supply valve at the house, the triangle stops moving.
2. I am thinking of installing a one way check valve in the line after the shut off valve.
3. I am thinking of installing a 2.1 gal. expansion tank at the 40 gal.water heater.
4. T and P valve is not discharging any water.
5. I do not know if the water meter has a check valve built into it.
6. This is a duplex with 8 people living there.
