I'd put the nominal 60# of pressure in the tank. TO check and adjust that, you need to release the water pressure (i.e., shut off the water and open a valve somewhere), otherwise, when measuring with a gauge, it will read the same as the water pressure. By putting in less than your normal pressure, you're causing it to store some water all of the time, and decreasing it's ability to store the execess caused by expansion.
