Sixdays
Water well drilling contractor
Valveman,
I'd have to pull the pump to get the specific information that you need. The pump is "probably" a 1 HP as it does approximately 25-30 gpm ............ I suppose I could disconnect the inlet to the tank, restrict the flow and see what flow rate the pump produces at a given pressure or it may be easier just to pull the pump.
Is there a range for a particular CSV or are they tailor made?
The static water level is going to be 15'
Thanks,
TS
Thanks,
TS
