Water Hammer Arrestor - 1/2" Threads
darinSD
Sam Diego, CA
I installed a Woodbridge Bidet toilet, and it uses a 1/2" MIP thread to connect to the toilet.
Ref here:
You can see the 1/2" braided hose in the second pic on the left side. While I can certainly sweat in a WHA, I would rather thread a 1/2" MIP to 1/2" FIP type, which I don't know if it exists or not. I have seen 3/8" style, but not 1/2" style. Ive also looked thru the entire Sioux Chief catalog with no results.
Any suggestions?
Thanks everyone!
Darin
RIP Terry.
Tuttles Revenge
Interesting.. never heard of that manufacture before. What is the water hammer arrestor for in the installation of a toilet?
But here is a 1/2 MIP water hammer arrestor. Its sold by proflo, but I would bet money that its manufactured by Sioux Chief.
PFXWHATD
darinSD
Sam Diego, CA
PFXWHATD
Thank you for the info.
The toilet has a huge thump every time the inlet valve opens which activates the siphon. Its annoyingly loud.
For the WHA, i was hoping to get a male to female inline type, which I have yet to find in 1/2" MIP/FIP threads.
John Gayewski
Iowa
PFXWHATD
Not sure about this guy's toilet, but one of those pictures in his link shows a booster pump in this toilet. Lol wtf?
darinSD
Sam Diego, CA
These toilets need a minimum level of water pressure to properly function. I guess having that booster pump would solve the problem if your supply is too low.
I never noticed that image before. That's really funny. :)
Tuttles Revenge
Toto Neorest units use a pump for flushing too. They store a small amount of water and then use a pump to push it down the bowl. They have to do it in order to keep the fresh water separated from the poopy water side. Tho the Toto also has a pull cord that you can use in case the power goes out.. also a battery back up.
Tuttles Revenge
Does it thump when the pump starts? Or when the pump shuts down? Water hammer occurs when the water momentum stops due to a fast closing valve.
John Gayewski
Iowa
The pump is for the sprayer? That's it's backflow device? Is there a upc stamp on this idea?
ipc , irc , upc , and other approvals I think the pump is because there is no tank and it needs a blast of water . but in any case evedently the toilet works is probebly legal but he wants to add a hammer arrestor . so just buy one that comes connected to an anglestop?
Tuttles Revenge
I think that is likely the valve opening that creates the flush. Again, not familiar with that brand but the Neorest that its modeled after has some mechanical valves that open to create the flush and they do make some noise as the pressure is released.
I never seen these , if anyone cares there is some info on it the pump is an ADD ON so Im not sure his has a pump . but again if he wants an arrestor well I suppose its easy
darinSD
Sam Diego, CA
I am going to try the WHA and see if there is any benefit. Cheap and easy fix if it works.
The thump is upon initial valve opening when the flush first goes. Would a WHA not help with that?
I would not think so. Water hammer occurs when water comes to a stop quickly.
