alexlacelle
I'm located in Ontario Canada and replacing my laundry room standpipe plumbing. I'm told that here I would be allowed to put the P trap below the floor (in my basement as opposed to the main floor laundry room). I tried searching for the rules regarding this but I cant for the life of me find anything.
Could someone tell me if this is in fact allowed, and if so, how tall the stand pipe can be from the P-trap? Surely if this is allowed the standpipe should be allowed to extend longer than the 30 inches I've seen referenced to under other codes? Furthermore, would I be allowed to run properly sloped pipe from the trap horizontally for any length then to a long 90 then vertically up into the laundry room?
This pipe will be vented and will connect to an existing 3 inch vent. I'm told this connection must be at least 6 inches above the flood rim for the washer. Is this correct or could I tie into the vent pipe in the basement as well, after the trap?
Thank you!
Thank you!
