Washing Machine P-trap Help
Scottsuperman
Tennessee
Hello
New construction and having problem with washing machine P-trap losing its seal when washer drains? Any suggestions on what changes need to be made to correct the issue from the attached picture?
Thank you in advance!!
Scott
Scottsuperman
Tennessee
Hello
Scott
By seal, I presume that you mean the "water seal", which blocks smells.
There should be an AAV at the top of the right-hand pipe.
John Gayewski
Iowa
Your standpipe should be between 18 and 24" long. Then you need a vent on the right.
IPC allows longer standpipes --up to 42, and AAVs.
I am not sure that is not an AAV atop the tall pipe.
Scott, is your symptom a smell?
Scottsuperman
Tennessee
Hello All
Thank you for your responses. That is an AAV on right. The issue I was having was sewer smell coming back through the washer drain. Turns out my problem was a faulty Sluter vent straight out of the box. Swapped with another and the problem disappeared.
