Venting a toilet next to bearing beams
lanthoma
DIY Junior Member
Nashville, TN
I'm remodeling a bathroom where none of the current plumbing is vented. The problem is that the 2x4 wall behind the toilet sits on a load bearing beam (picture attached). From below the subfloor, I can't get a vent pipe into this wall without cutting and probably compromising the beam. I thought the professionals come across this problem often enough and might have some suggestions.
-Lance
If we cant go through a beam, we find another location.
Nobody wants to mess with an engineered beam.
They might ask us to replace it.
Lightwave
Vancouver, BC
Easiest way to handle this would be to thicken the bottom few feet of the bathroom wall and run the vent line around the beam.
lanthoma
DIY Junior Member
Nashville, TN
The walls of my bathroom sit directly above beams on two sides, rim joists on the exterior wall, and a double joist on the interior (pic attached). So to get a vent pipe into any wall (or the lav drain down) would require moving joists or cutting into beams. What about running a vent pipe inside the wall to the lav, exit the wall (inside a vanity) and go through the subfloor next to the beam then run below the joists over to the toilet drain. Is this a suitable vent for the toilet? Is it termed 'wet venting the toilet'?
lanthoma
DIY Junior Member
Nashville, TN
I guess that's what I'll do then. I always thought pipes coming up through the floor rather than the wall looked amateurish, but I guess it's the thing to do in some situations.
AAnderson
Aptos, CA
If the toe kick is high enough, you can come up through the kick space, break around the beam and bottom plate altogether. Same with the waste from the lav and combine the vents in a common 2" above flood rim level above the lav sink.
