Elton Noway
I am aware federal regulations required that manufacturers put flow restrictions on their plumbing fixtures quite awhile ago (faucets, shower heads, mixing valves). The issue is I live in the country on a private well and as many of you know, water pressure can be less than ideal. Years ago I re-worked all the equipment in my well house, installed a Cycle Stop Valve etc. and boosted the household water pressure to 70psi. All was good... until I needed to replace some sink fixtures and ran into the flow restrictor issue. No problem at first because in the early days of flow restrictors I could simple remove them or drill them out. Unfortunately... I recently discovered manufacturers are "now" building the flow restrictors "internal" to the valve body of the faucet making them impossible to access or drill out! grrrr. I can appreciate the need for water conservation but I should be able to use water from my private well as I see fit. FYI: Simply replacing the faucet areator with one rated at 2.2 doesn't work when the faucet restrictor is located in the valve body itself and not in the areator. Anyway... I'm pulling my hair out trying to find a manufacturer or supplier of "quality kitchen faucets" rated at least at 2.2 gpm "or" still has their restrictor in a location I can remove or drill out). Any suggestions?
