Tub drain to copper
BSwanson
New York
My new tub has a PVC drain, and the cut-off stub of the pre-existing drain is copper. What's the best way to connect this?
Cass
You need to use a banded coupling that is specificly made to go from copper to plastic. You can get them at some L***s stores and most plumbing supply stores.
drain
Is the copper the main drain's riser, or part of the old tub drain. If it is 1 1/2" copper then you can solder a trap adapter onto it and then slip your PVC drain into it and tighten the slip nut. If it is part of the old drain you have to remove it and get down to the main drain pipe.
perrycat
that special fernco the guy was talking about is right, it's called a mission coupling, and it goes one side copper and one side pvc, ferguson's sells them.
Perrycat
BSwanson
New York
Connection is in the floor
Thanks for your help! I got one of those banded connectors (rubber sleeve with steel cover, 2 rings to tighten). I am not going to be able to acess that connection-it's on the second floor. Of course there is an acess panel, and Houdini could probably get to it. Is that OK?
