Trying to replace frost free hose bib, just spins and spins
Garrett29
Washington
I have a newer home with PEX plumbing and frost free outdoor faucets with anti siphon valves and this spring I tried to use the faucet and it wouldn't turn on at all. I pulled out the internals of the faucet and the brass tube is split in 3 spots. All my local hardware stores don't carry the brass tube itself and they don't carry bibs with anti siphon valves either so I decided to replace the whole bib. The trouble is I can't get my hose bib off the side of the house. I have turned and turned it until fatigue has set in but it just spins and spins without coming off. I'm now assuming that the connection in the house is not threaded because of the PEX, and I was ready to bust through the sheetrock in my garage to get to it but then found out my hot water tank is in the way. So my question is how are hose bibs supposed to be connected to PEX? Is there an alternate way to get this off?
No easy way to tell until you can expose the fitting used. It may actually screw into the fitting, but with PEX, that fitting is then just crimped in place. Ideally, they'd have used a drop-ear el, and anchored it to something solid. Then, it would be easy to unscrew it.
It's also possible that the hose bib is directly connected to the PEX, and rotating could have the PEX twisted into a pretzel.
It can also turn copper into a pretzel.
If it was installed using a Shark Bite, then it would make sense that it spins.
Normally we access from the back. If the water heater is in the way, it will be harder.
FullySprinklered
Georgia
Move down the wall and install a new one.
Crimp-ring PEX connections will spin, by the way.
