LarryLeveen
FWIW, I don't think that your subpanel would pass a current inspection...I don't remember the numbers, but there must be clearance on both sides, above, and in front of the panel...sticking a shelf over it, certainly isn't to code, either. The metal cover is to help prevent a spark from igniting something and for safety!
Installing a waterproof outlet cover is a simple job...take the existing cover off, screw the new one on. There are lots of different designs.
Ha! Yeah, I have no intention of leaving the subpanel uncovered like that. I welcome suggestions.
Regarding the outlet cover, I have seen a few videos that mentioned current code requirements for them. I think I know what to look for, though I just didn't know what the install is like. I'm guessing it's easier than the stuff I've been doing already!
One interesting question that remains is whether the GFCI receptacle was in fact bad. The one pictured is one I got and installed just to see if that was the cause of the other indoor receptacles not having power. That said, I doubt either are rated for outdoor use (something I learned was "a thing" after installing them, along with the code requirements for a cover). I think I'll do the right thing and get the real deal outdoor use GFCI and move those other GFCIs indoor to replace other crappy (stab-in-only) outlets in the workshop. I've also learned that there are GFCIs for 15 vs. 20 amp service, so I need to figure out exactly what the heck receptacle is needed. Any advice is appreciated. Thanks!
