Toto - need help narrowing down the field
John7
Vancouver, British Columbia
Hi
We have a house under construction and will eventually need 3 toilets. I'd like to get one installed soon!
Within the Toto line we are looking for the following features:
- 14-15" height (not newer "tall" height).
- Elongated bowl.
- White (or very near white).
- CEFIONTECT.
- Matching washlet available.
- any other features that would help keep it clean (cyclone vs. washdown etc).
If you could suggest 2 or 3 models that would really be helpful. I've read lots of stuff on your site but the "regular height" is an issue for my petite wife.....
Also, Toto's website only lets you filter for ADA height, not visa-versa.
John
John7
John7
Something like the Drake with CEFIONTECT
CST744SG-01
CST744EG-01
14-58/8" bowl height
Elongated
CEFIONTECT
It's the only one they have the meets all of that.
The double cyclone is 16-1/8" high.
And paired with a TOTO Washlet in Cotton for a better color match
http://terrylove.biz/home/105-toto-b200-washlet.html
http://terrylove.biz/12-bidet
Ok, so some post installation observations:
1. Flushing seems to only use about 1/3 of the tank of water. Is the flapper supposed to "float" and the tank completely drain or is that it? (I can hold the level and get a full tank flush if I really wanted to).
2. Careful assembly of the tank to the bowl, and the "three points of contact" and I end up with the tank about 1/4" rotated out of alignment with the bowl. Is there really that much play in the tank bolts? Presumably I can loosen them and align the tank better and retighten.
3. Plenty of gap between the tank (1.28 gallon) and the wall. It would seem even 11" rough is quite doable.
Otherwise a good experience. Seems to work well.
John
WJcandee
Wise One
New York, NY
It should use about 1/3 to 1/2 of the tank on the flush. The weight of the unused water adds velocity to the flush. This is typical of most effective low-water-consumption toilets. It should not empty. Here's a video of a typical (correct) Drake flush:
You are correct that the original Drake can fit on 11". My tank is pretty level and in alignment, but it took a couple of tries the first time I did one. After that it was cake.
