Schnabeltasse
Hi, I’m new here - hope this is the right place for this question.
I’m about to pour the slab in a basement that will likely never get finished but will have some shop space and storage. I wasn’t going to put a bathroom in there so wasn’t planning on underslab plumbing but as a last minute thought I’m wondering if I should at least put some provisions in for a toilet. I already have an ejector pit in the ground that was intended for a future sink in the shop area (plumbing entering the pit above slab through the lid). If I wanted to add a toilet, what would I need? I was thinking put a short 3” pipe from the pit a few feet over and box it in to keep concrete away from the pipe so I can later access it and put whatever fitting on it I might need at the time I install the toilet or is there such a thing as a standard toilet fitting I can install now? Do i need a vent if the toilet is only a few feet from the pit? My engineering mind tells me no since the pit will have a 2” vent and the toilet will drain to the pit above water level so should be able to pull air through the pit vent but maybe I’m missing something? How far away could the toilet be in that case? If I wanted to add a shower drain (or floor drain etc) should I run it separately to the pit or can it be tied into the toilet drain? Would it need its own vent?
Schnabel
Schnabel
