Toilet gasket
Peterl
cal
Whats a good toilet gasket now? I used fluidmaster and its leaking I think. I installed on 2020. Thanks
Usually something is wrong maybe the ring is too low . why did you use a gasket in the first place? Wax is all I use on "normal install"
Wax has its weaknesses. You must place the shims before dropping the toilet onto the wax. You must not rock the toilet. Plunging the toilet into a partially clogged soil pipe can blow the wax out.
