I guess I haven't seen it all.
Are you referring to the fact that the overflow is not centered?
Question: How does any overflow water get to drain through this overflow when the screw cap is on?
Not only is it not centered, but the overflow plumbing pieces where the overflow trim is supposed to be screwed onto was never installed. There's only a cut off PVC pipe and it's sitting slightly back into the overflow cutout. So, I am thinking I will drill 4 small holes in that screw piece to allow water to drain through it's hollow body. The threaded part is hollow. I can snap the overflow trim pieces on afterwards.
Unless, there is something else I can use. I have searched overflow parts and see nothing that would work.
What was this guy thinking? What was his plan? He was a Master plumber. BTW - he died, so I can't call him to fix it.
