Mae-Ling
I have a Tankless heater, ever since I bought the house 1.5 years ago the T&P valve has been discharging slightly when you turn off a hot water tap. I was told this is normal. Is it?
Now the T&P valve is leaking constant when you use hot water. The water temperature is not overly hot coming out of the relief vlave, I can hold my hand in a pail of it for a minute or so. Wanted to take a temperature on it but do not have a thermometer.
The tank was at 50C and I turned it down to 40C and it leaks a lot less water but still does leak a little.
We also had a power outage if that makes any difference, although we were on holidays, however 4 showers were taken and 3 loads of laundry done before it started to leak after we got back.
Figuring I'll probably just change the T&P relief valve and see if that does it.
Any other thoughts or ideas?
