Studor Vent for powder room
Kezug
Indiana
I am finishing a powder room (sink and toilet only) that already has the piping in the ground for the toilet and right behind the toilet coming up the wall is a 2" line coming up about 4 feet and its capped off.
I am assuming that this 2" PVC behind the toilet is for venting AND for my sink drain? So I am thinking that I would connect the sink drain to it using a Sanitary Tee for the waste to go down and going up the Tee would be a connection to a Studor Vent.
Is this how I should be planning this?
If so, what size would I use for the actual sink drain? (1.5")
NOTE: that 2" pvc coming out of the ground has no where to go up through the first and second floor on out to the roof like a normal vent.
Tom Sawyer
Maine
First off I don't think you should "assume" anything. You need to know for sure where that 2" pipe goes and moreover, how and where it is connected. As for the studor vent, you live in Illinois where I believe the code does not allow them.
Kezug
Indiana
Actually, I live in Indiana...just corrected my profile as I am not sure why it was listed as Illinois. Good point on the 2" and what it may or may not be...I will dig up some old photos to see if I have a pic before the cement was poured
Kezug
Indiana
I found a pic...does this provide enough detail as to what that 2" pipe is for?
The toilet inlet is right next to the ladder and just to the right of that is the 2" that I described above as being behind the toilet (its behind as the way I am putting the toilet in.
JohnjH2o1
Florida
It looks like it is a vent for the toilet but if you use a sutdor vent it has to be accessible.
John
I find it incomprehensible that if they put in piping for a basement bathroom that they did NOT provide a vent connection at the ceiling since they would have known you needed it. AND, it would have been a simple process to install it when the building was constructed.
Tom Sawyer
Maine
that looks like a drain for the lav to me but depending on how it was piped below it could also be used as a wet vent. If you are under the IPC then chances are good that you don't need to worry about venting the toilet as long as it is connected to a line that's vented somewhere in the house and I'm pretty sure it is.
Kezug
Indiana
As do I, I was young when they built and I am upset that I failed to recognize this during the building process. However, I am more upset that it passed inspection and even more upset that my builder didnt catch it.
An AAV (Studor is one brand) cannot be the only vent in a system, you need an atmospheric vent also somewhere on that system.
Kezug
Indiana
Ok, I have a better picture of what my basement looked like before the cement was poured. I also put in some labels of the pipes that are in the pic.
My questions
1) Can I put a studor vent on the questionable pipe? If so, how high should the studor vent be? (NOTE: this will be in an open room as its inside my furnace room)
2) Can I tie my sink drain waste into the same questionable pipe but below the studor vent?
Kezug
Indiana
I am hoping someone can chime in and lead some advise being that I provided some more detail (perhaps all that was mentioned above apply but this picture shows more detail).
Thanks
Tom Sawyer
Maine
Sure you can put an AAV on the pipe ut whether ir not it vents anything is another question altogether.
