Standard Modernus bowl replacement
I'm very glad I found your forum-- I've got a busted Standard Modernus (on the bowl, where the seat bolts on). Here's my tale of woe: my parents house, built in 1841, has a half bath under the staircase (tiny, but theoretically serviceable). From the time I was born, the 1/2 bath was used as a closet. The sink worked (if you took all the junk out of it) and there was water in the tank & bowl, but if you moved more junk and flushed it water would come shooting out all over the room from the broken bowl.
Flash forward 35+ years: my mom recently spent a few weeks in the hospital and is currently unable to make it up the stairs to the (functional) bathroom. I've done a fair bit of renovation & replaced a half dozen toilets over the years, so I volunteered to come over and replace the ol' commode. My dad did some poking about and preparation and called to abort the mission-- apparently the drain for this thing is located several inches forward of "modern" (no pun on the modernus intended) drain placement? Replacing with a $99.99 "toilet in a box", if this is in fact the case, would put the front of the seat up against the sink in this teeny bathroom.
Can anyone confirm this difference in drain placement, and if anyone has alternative ideas (cheap ones, we're not rich folk) I'd love to hear them. Obviously, I'd really prefer not to try moving the 75+ year old drain's location in the floor if possible! Or if I could find a bowl which would match up with the Modernus tank, along with the L, gaskets, flange, etc. to attach to the existing (functional) tank, I'd do that rather than a complete tear-out, floor replacement, etc. Our budget is in the $250 and under category!
Thanks for any wisdom you might bestow!
--Jim
