soil stack problems
mike08054
In the course of a bathroom remodel the plumber cut the soil stack to allow the addition of two new drain lines. In the section that was removed it is easy to see that the accumulated build up on the inside of the stack has reduced the capacity by half or more. Right now there are no blockages but it seems that we're headed in that direction. The house is about 60+ yrs old.
Should anything be done now to prevent problems in the future. I'm a little worried that agressive action will create a blockage. Is there some way to do regular treatments to slowly eliminate the buildup?
Master Plumber Mark
www.weilhammerplumbing.com
lime build up
that is a nasty situation all around
the stack is filling up with lime.....
it is probably best if to change out the
entire stack if possible ...while you are in combat already.
if not you can try to get someone to rheem out
that line with a large cutter... maybe work??
or it will break it up jsut enough to stop up the line further..
you can pour pure vinegar down the line and maybe it
will eventually break it down.... although that could take forever.
muratic acid will eat through it too ....very quickly
but its a very nasty smelley thing to mess with...
I have gone the Muratic Acid route before.
just change out as much of the stack as you can
while you got the chance to do it...
pipe
If it is a cast iron pipe, then the accumulation is rust and nothing is going to remove it. But it seldom creates problems in a vertical line, unless it causes stress and the pipe cracks.
mike08054
It is a black paste substance and it is soft. I'll take a closer look tonight and see if I can also take a picture.
mike08054
It's definitely organic (waste) not rust or lime.
Master Plumber Mark
that is not organic matter........
what you have in the pipe is really not organic matter anymore
it has actually broken down further than baisc organic matter
and the only term that can really descirbe it properly is
....................funk...................
looks like it would be best to either grind through it
with a large sewer calbe and lots of flushing of water
or change out that funkey pipe...
mike08054
I'm a bit worried that the cleanout might cause a clog since there's so much stuff in the pipes. Should I be concerned? Would it be better to do regular treatments with an enzyme based drain cleaner?
Master Plumber Mark
rheem it out first
Spend the money for a drain clenaing
the only cure is probably a good rheeming out
with a good sharp cutter....by someone who knows how
to cut through tree roots...that does this all the time
it is his job to flush the line and remove all the funk for you .....
was this a verticle or horizontal pipe???
After he has rheemed out the pipe
you can try something like a few gallons
of muratic acid being poured down in the toilet
full strength over a few hours every year or two to
sort of break up any new growth.....
ask a local drain cleaning guy his advice.
its not a fun job either way you shake it.
Gear Junkie
Virginia Beach, IPC country
I would either jet or use a 4 bladed cutter to clean the line. This is the before and after pic of a urinal line. That's what 50 years of old man piss looks like.
