Dgold
Avoid DIYer
Hello,
Looking for advice on a softener.
I'm on municipal water in San Diego. Water company analysis here claims a max hardness of 310 ppm (depending on the source), but... and I've tested my CH multiple times with a Taylor test kit @ 400 ppm (~24 gpg). From what I've found online, it appears that a 64,000 system will fit my needs.
I do not have any color stains in my toilet tanks, and I do not smell any odor in the water.
In a previous home, I had a Fleck 5600 softener valve, with a 12-day wheel adjustment. While maybe not the most efficient valve ever, it was extremely simple and easy to service. Ten years later, I see that valve is headed for obsolescence, but I've also read that this valve will be available to on-line resellers, and if so, I would suspect parts will remain available for a long time to come. Is this sound logic? I am someone who values simplicity and long-term reliability over digital displays, or maximum efficiency.
I was wondering if the forum would still recommend a 5600 econominder valve - despite the potential that Pentair may discontinue it? Or is there another valve that the forum would recommend?
Lastly, what does the forum recommend in terms of valve material (plastic, brass, stainless), and brine tank shape (round vs square)?
Other info... My home has 3/4 copper supply lines where the softener will be installed, no height / clearance issues, and my water pressure is regulated to 50~55 psi. Two adults, two small kids. No idea what our actual usage is because we also have landscape irrigation (which wouldn't go through the softener).
Thanks very much in advance.
