So I spent about 3 hours over at one of my rental properties trying to clean out a completely plugged tub drain. Ran the snake down the drain and it came up the overflow pipe, went down the overflow and it came up the drain, just couldnt get it to go where it was supposed to. In the process though I did pull out one of the caps to the shower faucets, but surprisingly that wasnt causing the blockage. I poured a bunch of chemicals down there and at some point established a slow partial flow.
There was no grate over the drain and there are small kids in the house. My concern is that there are more foreign objects down there of the hard plastic type and maybe that is preventing me from getting the snake to the right spot and that the chemicals just dissolved hair that might be caught on that foreign body. There isnt an access panel to get at the drain to take it apart and I'd rather not start cutting drywall. Any thoughts? If it isnt a foreign object, is there some trick to getting the snake to go the right way?
