Good evening.
I have been lurking on this site for some time and it has been a very useful resource.
i now have my own issue to post and hope for some good advice and guidance.
we had a powder room toilet leak. The leak was slow but overnight and it slowly seeped under the wall and into the adjacent rooms which has caused the carpet to get wet as well as some wood floor. It leaked slowly over an approx 10 hour period. A couple rooms have no baseboards as we are amidst replacing them. All sill plates are pressure treated 2x4s on a slab foundation.
we will remove part of the hardwood floor as it appears to have caused some water marks/stains in the seams between the planks but have placed a 1,750cfm fan to blow on the affected planks and toward the bottom of wall where water leaked under sill plate. No baseboards here.
We pulled back the wet carpet and cut out the padding in closet area. We used a shopvac to suck up any moisture from the carpet. We have a 930cfm fan blowing in this affected room and directed the air to the sill plate where water seeped under.
In the powder room we have a 930cfm fan blowing toward the sill plate where water seeped under. No baseboards installed here.
carpet is dry and I don’t feel any moisture on the sill/bottom plates.
Drywall did not get wet as there was no deep water standing in any room.
for how long should we continue this?
What else should we do?
Should we remove baseboard in the rooms with carpet to ensure it is dry behind them?
should we be spraying any concrobium Liquid Mold Remover as a precaution, on the sill plate, carpet tack strips, and concrete slab? Anything else?
looking forward to your collective input.
we are about 9 hours into fans blowing in powder room, closet/carpeted area, and the wood floor in adjacent area.
