I've just finished installing the supply valves (4x 1/4 turn brasscraft compression to 1/2" copper tube) and am having very slight leaks in all of them. Enough to make a damp spot on toilet paper after sitting overnight, but no drips (yet). I've used these before for in both toilet/sink applications and had no problems, but I suspect my stub was more pristine.
I really don't want to leave it "leaking" but am concerned with re-fitting the valves and making it worse. The stubs were a little on the short side and had soldered caps. Since they were shorter than I would like, I de-soldered them instead of just cutting off. The tubes are definitely "tinned" at the tip, but I'm not sure if that extends to the ferrule area.
Suggestions on how to proceed? Do I disassemble/clean/replace ferrules as good measure? Do I try to solder on an extension and got at it with a brand new section of tube? Am I over-tightening (since I did muscle them in a bit)? Are there telltale signs that the assembly isn't together correctly that I can avoid?
Thanks.
Dan
Thanks.
Dan
