Are you sure the blue handle valves are fully open. I like to open them all the way and then turn them back in just a bit. The next person can rock the valve to see which way they turn without breaking their wrists.
Nothing obvious looks amiss.
Yes, I also pulled both valves completely out and the flow was good with no valves…Is it possible it gets restricted somewhere after leaving the new valves? I openned and closed the blue valves a bunch of times to clear out any possible blockage…some crap came out but everything is the same.
EDIT
This has been an issue since I moved in, I took off the big brass manifold thing and it and everything flowed fine. Could the moen valve inserts be wrong, the holes seem small…and I notice 3 different types on amazon? Maybe someone put new ones in and they were wrong if thats even possible. I am at a loss and only thing I could think of is the tap handle valve or right behind the valve is messed up(wrong size or restrictive) or there is some sort of regulating valve in the system I don’t know about thats messed up. I will attach another pic showing 3 different types and maybe someone who has dealt with this might spot the issue immediately, I used the 1224 as that was what was in there and matched the items at the hardware store.
