Silicone on P trap threads
JackJ59
Wisconsin
I'm thinking that this wasn't a good idea, or necessary. There was a small drip, but rather than try tightening (or if the threads were worn/stretched, replacing), the plumber used silicone caulk, saying that it would be able to be "broken" easily if I need to access it in the future. But even if that, will I be able to re-tighten it after? It would be hard to remove from the threads, wouldn't it be?
If you ever want to change it, and if it does not easily break free, you can hacksaw the old one out. They are cheap.
Sometimes, if the pipes aren't well aligned, those compression fittings don't seal perfectly. Silicon is a coverup in that situation. Some of the stuff is just funky quality.
JackJ59
Wisconsin
Thanks for the replies. He was a plumber; or at least the plumbing company billed him as one and priced it accordingly. I was surprised that he didn't know what his "Thrift" chemical was, handing me the container when I asked. So it caused me to question some of his other decisions/comments.
Any thoughts on the nature of this joint (if that's the right word)? Was it done correctly, and should a snake be able to navigate this turn ok? The pipe on the right is coming from my kitchen sink, and then the pipe on the left does a long run .
You are are now talking about a where that waste continues after it drops to the basement.
Not terrible, maybe, but you should not use a sanitary tee for a horizontal to horizontal drain turn. He did provide a cleanout, which is good.
